TCS connection 1970, 454 - NCRS Discussion Boards
  • harry quinones
    A harness question once again. This time it's the connection to the TCS at the gas pedal.
    Is there proper polarity that has to be maintained or does it matter?
  • Bill Clupper
    Re: TCS connection 1970, 454
    There is technically no polarity required at either this connection or the A/C clutch you mentioned earlier. However I believe the A/C connection is indexed by a punch tab on one or both of the terminals in the compressor having to mate with a slot in the plastic connector that holds the terminals.
    • Bill Clupper
      • harry quinones
        Thanks so much for the response Bill.
        • harry quinones
