Well folks, looks like my overheat on the 1960 270 hp was a combination of things and looks like we've solved them with everyones help.
1 bad fan clutch,even new ones don't work sometimes
2 bad rad cap, not holding pressure, only 7 lbs
3 timing off
4 heat gauge 10 degrees higher than actual
5 tight new engine
6 anti-freeze mix ratio
7 bad heat riser(yes even NOS don't work sometimes)
The last problem was diagnosed/solved when the gas perc'd in the carbs. The heat riser was sticking. Special thanks to Bob Kunz for that one.
Thanks all! Hopefully we finally got it.
Don
3 timing off
5 tight new engine
Don
