C3 Rear Spring - NCRS Discussion Boards
C3 Rear Spring
  • Chuck Watson
    C3 Rear Spring
    How much of an arch should there be in a stock rear leaf spring for a 1969 Coupe? It has a 427/400 and 4-speed. (Measured on the car not loose and unsprung.) I'm trying to determine if mine should be replaced or not.
    Chuck W.
    #31154
    • 15610
    Re: C3 Rear Spring
    The best way to determine if the spring is serviceable is to install new link cushions, verify that you have the correct link bolts, then measure the "D" dimension, which should be in your AIM and CSM.
      • 15610
      Re: C3 Rear Spring
      • Gary B.
        • February 1, 1997
        • 6979
        Does the spring show any arch in the car?
        Chuck,
        Does the spring show any positive arch as it is? Or is it either completely flat or bent past being flat? Is it a 9-leaf? Or do you have the F41 suspension and the heavy duty spring?
        Gary
        • Gary B.
          • February 1, 1997
          • 6979
          Chuck,
          Gary
          • Chuck Watson
            Re: Does the spring show any arch in the car?
            The spring it the standard 9 leaf. It looks flat with no arch at all.
            Chuck
            • Chuck Watson
              Chuck
              • Gary S.
                • July 31, 1992
                • 1628
                if you are able you might try to take a small straight edge, say a 12" ruler to ensure that it is flat. The nine leaf springs should have some arch in them. When I first checked my 72 visually it appeared flat but with a 12" metal ruler against it, there was definetly a slight arch to it.
                Gary
                • Gary S.
                  • July 31, 1992
                  • 1628
                  Gary
