The only reference I find for tread dimensions on my '64 is in the owners manual. It lists 56.3" front and 57.0" rear. Is tread measured from center to center of the tire tread? I want to use this dimension to position the rear torque arms on the chassis before proceeding to toe and camber adjustments.
On the exhaust system for the 365 SHP engine is the heat riser valve used and, then, only on the right side?
Thanks again to all of you for your excellent help.
Pat McInerney
Pat McInerney
