I am hoping someone can answer a simple question for me regarding the installation of a carb heat shield for a 69 350. I've only had the car for a short time and pulled the carb. The previous owner had the stainless steel heat shield sandwiched between 2 carb gaskets. When I put the carb back on I want to make sure I do it right, and from looking at the AIM and from what I recall, I think I'm only supposed to use one carb gasket directly on the manifold, with the heat shield on top, and then the carb goes directly over the shield. Is that correct, or do you get a better seal the way the previous owner had it?
Thanks!
Thanks!
