Hi Joe (or anyone else for that matter)...I have a 66 TIM & JG coming, but, in the meantime, what are the correct pulleys for my new 66 427-425? I figured the crankshaft pulley should be the cast iron unit with 108 for the last 3 digits, but it appears to be stamped. I have no clue on the water pump, and the 693 alternator is wrong with a smaller pulley which I suspect is wrong. The car has no PS, just alternator, water pump, and cranshaft belting. Since this is a BB driver, If I were to get one of the conversion kits with the original pumps etc, What pulleys should I buy for everything going that route? Thx!....Craig
Pulleys for a 66 427-435 - calling Joe Lucia
Re: Pulleys for a 66 427-435 - calling Joe Lucia
Craig-----
W/O power steering:
crankshaft pulley-GM #3863108 (available)
w/pump pulley-----originally GM #3864480; superceded by GM #3906656 (available)
alternator--------GM #3929387 (available)
W/power steering
crankshaft pulley-------same as above
w/pump pulley-----------same as above
alternator pulley-------GM #3871242 (discontinued; reproduction)
p/s pump pulley---------GM #3878245 (available)In Appreciation of John Hinckley- Top
Craig-----
W/O power steering:
W/power steering
