1961 rear axle bearing - NCRS Discussion Boards
  • Joe D.
    • April 30, 2002
    • 382
    I had new rear axel bearings put on my axels. One side of the bearing is completly sealed and the other side has a spring in the center of the seal. Which is the side of the bearing that faces in towards the differential? They installed the bearungs with the spring in the seal facing the differential. Thanks, Joe
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 1961 rear axle bearing
    Joe - seach back about a week or two ago for long threads with Dale Pearman's advice on how to install the bearings correctly...Craig
