I need you help in determining what engine I have. The pad is stampedin two rows, V1215AWK is stamped above 1KL154012, The heads have cast number 14101083 and the date code (I think) of K158. The seleer said it was an L82 with TPI. It does have TPI, but I'm suspicious of it being an L82. Any and all information will be greatly appreciated. Many thanks in advance.
What engine is this?
Re: What engine is this?
Donald-----
It's not an L-82. Its an LB9 305 cid TPI engine originally installed in a 1989 Camaro or Firebird built at the Van Nuys, CA vehicle assembly plant. The cylinder heads were cast on November 15, 1988 and the engine was assembled at Flint, MI on December 15, 1988.In Appreciation of John Hinckley- Top
