In a previous post I mentioned that I had a tach drive distributor without a vacuum advance, some electronic piece in place of points, a condensor, and a ballast resistor in the circuit. The engine is a 327 with a Holley 4 Bbl. I have the distributor removed now, and found the following numbers:
"461" raised numbers in the cast body
"1110985 Delco Remy O F 10" on the aluminum strap
Any ideas on what this might be ? Previous replies confirmed that this is not an original 63 setup, mentioned that some 283 2x4 applications had centrifugal advance only, but also mentioned that the ballast resistor is not required with electronic ignition.
Steve
Steve
