67 Questions - NCRS Discussion Boards
67 Questions
  • Zachary K.
    • March 1, 1986
    • 162
    67 Questions
    Just a few 67 questons. 1. Glove box contents, was a cloth bag used for the hardtop wrench and mounting bolts? If so, can someone describe the bag size, stitching color, drawstring color, and if the bag had stitching on both sides or across the bottom and one side. Did mid years come with seat shimms as C3's did? I think somewhere in the assembly manual I found or remember seeing that there were shimms placed under the seat track mounting legs.
    2. Original jacking instructions, were the corners of this label rounded off to some degree? All aftermarket jacking instructions that I have seen, have the corners squared off, and I haven't seen or have an original to compare.
    3. Can someone give me the true thickness of an original rear storage cover board.
    Thanks in advance!
    1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
    1969 L71 LeMans Blue, Bright Blue Convertible
    1970 L46 Monza Red, Light Saddle Convertible - Duntov
    1976 L82 Classic White, Firethorn
    2013 LS7 Black, Ebony, Convertible
    Moved on -
    2006 LS2 Black, Ebony, Convertible
  • Zachary K.
    • March 1, 1986
    • 162
    Re: 67 Questions
    I found the assembly manual page showing the shimms. UPC 1 - Sheet J 5 - item number 13 - part number 3755650. Were these ever installed on any Corvettes?
    Moved on -
