Hi,
I have a 1982 Vette. The other day the car wouldn't start (starter heat problem). A "friend" jumped the starter solonoid with a screwdriver and the car started. But now the alternator doesn't work. I took the car to a shop and they replaced the alternator. I had them replace the starter at the same time. The car starts but the new alternator blew. They replaced the alternator again and they say it is charging with the maximum output. And it is stuck charging at full charge.
The shop says either something in the dash board is fried or there is a wire missing. I can't believe there is a wire missing because it used to work.
All of the fusible links test ok.
Someone said there is a ground wire at the starter and the mechanic may have put the wire to the BATT connection on the solonoid. The mechanic said there is no ground wire.
Anyone have any ideas?
Ed
Ed
