I while back I read a post regarding cleaning a frame. I believe someone talked about removing undercoating to get down to the metal frame. Something about heating a small area and then scraping off the undercoating and grime with a putty knife.
My car has had undercoating applied at some point. I plan to do some rear suspension work soon and I would like to begin cleaning up the frame while I have the rear end apart.
Can a heat gun, I think they are used for stripping paint from furniture, be used effectively. I know that I don't want to heat the fiberglass and cause some warping.
Second, what is the best paint to use to repaint the areas I clean.? I am not worried about NCRS points, the car is a driver. I want something that will last and I can keep clean. Is the POR-15 a good choice.? Any others.
Ryan
Ryan
