numbers, again - NCRS Discussion Boards
numbers, again
  • john pickens
    numbers, again
    Hi, new to the board and to the hobby. looking to buy first midyear.
    have found a 66 convertible,touted as NOM. vin is 194676S119622, block
    code 3782870, suffix 19622 F101HT. not seen the car yet, but i'm told
    is 327/350. black book says block is a 65.
    any opinions as to the possibility that this engine could be authentic despite
    cast code? i do not yet know cast date(and may not be able to get it from
    long distance). the cars looks good, and i plan a daily driver only- but would
    prefer to be able to at least give potential buyers a maybe on original
    engine. any of you likely to buy this car if looks and runs well? price
    is 32000 asking .thanks.
    Re: numbers, again
    John -
    "NOM" means non-original motor, which this '66 appears to be.
    The 3782870 block was used from '62-'65, 3858174 in '66, and the "HT" suffix was used for the non-optioned (no A/C, P/S, T.I., K19, etc.) 327/350 from '65 thru '67.
    The car's VIN indicates it was built approximately April 18, 1966; the stamp pad engine code (F101HT) is missing a digit - the date field should have four digits. If it's 101 or 0101, that was a Holiday (no engines built on New Year's Day), and it's highly unlikely that an April car would have a January engine; data on other 1966 "HT"-engined cars 500 units before and after this one shows that all have April engines.
    The car is advertised as having a non-original motor (NOM), and that appears to be the case ('65 or earlier block), and the pad appears to have been altered by adding the car's '66 VIN derivative.
    • Joe C.
      • August 31, 1999
      • 4598
      Re: numbers, again
      John:
      Be sure to check the block casting date on the rear of the block (bellhousing flange),on the upper right side. It should be in the following format:
      X YY Z
      where X is the month (A==Jan, B=Feb, etc)
      YY is the day of the month
      Z is the year (in your case "5" for 1965)
      if the year field is 2 digits (e.g. "65"), then it is a non Corvette "870" block.
      Joe
