NEED HELP WITH 58 PROJECT CAR,CAR SITTING OUTSIDE FRAME RUSTED SEVERAL PLACES.ARE PEPLACEMENT PIECES AVALIABLE OR SHOULD I LOOK FOR A NEW FRAME? NEED HELP DECISION TIME???? THANKS ALWAYS. BILL #291
58 FRAME PARTS
Tags: None
- Top
Re: 58 FRAME PARTS
Yes, there are vendors for everything you might want to do.
Some sell frame components, for example:
Corvette Central http://www.corvettecentral.com
Chicago Corvette Supply http://www.chicagocorvette.com
Some do the repairs, for example:
Caledonia Classic Auto (MI) 616-794-5026
Randy Church Restorations (MI) 800-296-8951
Graceway Machine (CA) http://www.gracewaymachine.com
Some even manufacture replacement tube frames with attachment for C4 suspensions:
Auto Design (IL) 708-385-8222
Southeast Frame (FL) http://southeastframe.com
I'm sure there are many more.- Top
Re: 58 FRAME PARTS
Yes there is a lot frame parts available, May want to spot blast some of the bad looking areas to determine the real damage before cutting and replacing. Good rust free frames are available in California at Cranes Corvette (see www.cranescorvette.com)in San Diego. Don't forget to record the vin numbers on the orginial frame for your records. (These Numbers may be double stamped on the drivers side)
Good Luck . . .- Top
