Speedometer On Drugs - NCRS Discussion Boards
  • Bill S.
    • August 31, 1999
    • 104
    OK this is baffling me -- Looked down at the speedometer when cruising along at 55MPH and all of a sudden the needle is bouncing around 80 MPH and flickering there for about 15 seconds - then the needle settles back down to 55 mph where it should be. This happened several weeks ago -- same deal. How could a cable be half broke? Or is it in the speedometer head assembly or whatever this is called? Thanks Bill
    Vette Links
  • Ed McGettigan
    Re: Speedometer On Drugs
    Check to see if your odometer is still working. I had a similar situation where the speedometer bounced all around the dial then settled down and has been fine, however, the odometer hasn't turned a mile since. I've been told that this usually means the gears in the odeometer are shot. Not sure if this is your trouble, but worth checking...
    Ed #31248
    • Dave Henderson
      Hope you speedo knows when to say when. I'm lazy but I had success greasing my speedometer cable and eliminated the bounce about 75%. I pulled the cable off the trannie and injected speedo cable grease with a grease gun. Got it to a tolerable flutter in WOT, and it was completely stable in cruise mode.
      I am not sure whether the same can be done with the TACH cable, perhaps a learned non-yuppie can join in with more advice.....
      good luck
