Hello,
I have a 66' with a drivers side headlight problem. At first the light would not rotate unless the wheel on the motor was turned manualy a turn or so and then it would work with the switch as normal. Now after closing the lights with the switch the bucket turns freely and will not open with the motor. When it turned freely the first time it sounded as though there was a piece loose and rattleing around. Any ideas as to what this might be and how to fix it? If I drive the car like this will the wind flip the headlight open?
Thank You,
Ian Spanic
Thank You,
Ian Spanic
