If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
When looking for a Transmission for my car what is the best timeframe to have a tranny dated to be considered correct? I ahve serial number 3671 which is an early Nov car and need to get a new transmission and figure might as well go for the correct date. Any suggestions? Would teh tranny be dated a week earlier? Two weeks? Month?
Like other dated parts, the 'typical' skew was 2-6 weeks prior to assy. But, in-plant inventory control was NOT a religious FIFO/LIFO scheme in those days. There was a reasonable degree of 'spread' in component dating for a number of reasons. NCRS judging rules presume a 6-month window prior to assy as the norm. There are isolated cases where individual judging guide books make exception based on what we know about a given part, but these are exceptions vs. the norm....
Since your transmission will be a replacement/restoration component vs. the correct/original (it was only factory original once and that's history), why knock yourself out trying to tie that date down too tightly? If a replacement assy is available that meets the 6-month window criteria and time/cost escalate dramatically to get closer (2-6 weeks), I'd say take the bird in hand and let club rules work for you....
But, different folks have different pride levels in their restorations and that's something one doesn't dictate. However, Noland Adams' Vol 2 book is pretty interesting as he gives participant survey data from '63-67 cars that are alledged to be 'untouched'. If you flip through those pages and follow the date makeup of a given car by VIN, you can see the statistics at work.
There WAS variance and the standard deviation was larger than a lot of folks think! This adds credence to the club's 6-month window policy....
music to my ears Jack. I have seen a couple of trannys made 2-3 months prior so I will look at pursuing those and not worried about a real close date. Perfect for me!!!
It depends on which judging you're talking about. In bowtie judging we have the car on stands and we check all numbers on tranny, rear, etc. that, of course, is for original unrestored cars, and if you're missing your original tranny that makes it more difficult to score well--but there are two different criteria depending on which judging you're having done. To my way of thinking, there are more than 100 restored cars for every unrestored car that is in good condition. (C1's).
Mike ernst
NCRS doesn't specifically verify cast numbers/cast dates in Flight Judging, but they ARE viewed/assessed in Bowtie Judging (Flight=restored Corvette category, Bowtie=unrestored Corvette category). However, we (NCRS) are not the only factory concours judging circuit and others (E.g. NCCB/Bloomington) do make the long, hard crawl under the chassis to read/verify tranny numbers....
First of all your car was built on December 6, 1961 not early November.
In flight judging the transmission can be seen as a correct T-10 or not but that's about all. Casting numbers on the three major components cannot be read from a distance BUT in judging your car I'd look for a bow-tie embossed cast on one side of the main case as well as the small metal tag indicating close or wide ratio gears.
In Bow-Tie judging the casting numbers and dates would be noted as well as the Borg-Warner assembly date. Also, in 1962 the Corvette's VIN derivative was stamped in close proximity to the assembly date stamp.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
