C2 Fender skirt holes - NCRS Discussion Boards
  • Mark F.
    • March 1, 2002
    • 174
    My '65 convertible is equipped with an L-75 engine, powerglide, and power steering. The left inner fender skirt has two holes drilled into it. They are about 4 inches below the fender edge and even with the #1 spark plug. Are these holes factory-drilled, or the result of an aftermarket accessory being installed? Before I repaint the skirts, I need to know if I should fill these holes. Thanks for your help, Mark
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C2 Fender skirt holes
    My first Corvette was a 64 convertible with air conditioning. It had two holes in the passenger side so that after removing the spark plug wires a long extension could be used to remove the front two spark plugs going through the inner fender skirt.
      Mark -
      Sounds like aftermarket holes - can't think of anything that would be in that location with your configuration.
      • Mark F.
        • March 1, 2002
        • 174
        Thank you, Jim & John. Tought so. *NM*
        • Mark F.
          • March 1, 2002
          • 174
          Sorry, forgot the "h". *NM*
