I have a 1968 427 A/C, P/S equipped car. The idler pulley on the car is
grooved, which I believe to be correct. The 68 Corvette assmebly manual shows a grooved idler pulley configuration. I have noticed 69-72 cars with
smooth idler pulleys.
I am having trouble locating the correct belt for the idler pulley setup. The assembly manual lists the GM part number for the idler belt as 3940990. Well I ordered that belt, and it is way too small. I can't even get it over the water pump pulley and the crankshaft pulley. Does anyone know the correct part number for the belt that goes over the water pump pulley, the cranskaft pulley and the idler pulley for my car? All the other belts, which I ordered using the assembly manual as a reference, fit fine, including the A/C, A.I.R., alternator,and P/S, so I am pretty sure the car has the correct pulleys.
