If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
What is the correct procedure for reinstalling the radiator support? Is the radiator support reinstalled with the same number of shims at the frame and the body lifted to the mounting holes; or is the body mounted to the radiator support and the the radiator support shimed at the frame to a specific dimension. Or is there some other methodology used.
There is no magic in how many shims are used at this point. If the original shim packs are still there and the frame and body have recieved no damage, then the original amount of shims will probably be correct. But most of these cars have had damage and then all bets are off. Just bolt the support up to the body and shim to suit your needs.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
