Harmonic Balancer - NCRS Discussion Boards
Harmonic Balancer
  • Ray C.
    • June 30, 2001
    • 1132
    Harmonic Balancer
    Hi!
    When installing the harmomic balancer on a 1965 250 HP small block, how do you determine when the balancer has bottomed out or in its correct position.
    Thanks for any help!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Gerry Proctor
    Re: Harmonic Balancer
    The damper will be bottomed out when it can no longer move on the crank. It will contact the crank timing gear and go no more. As to the right position, as long as you've installed the woodruf key on the crank, it can only go on one way. Ensure you are using a damper installation tool. By hammering on the damper you may damage the damper and will likely damage the thrust bearing. You do not want to entertain either one of these gremlins.
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks! Ray
      Ray Carney
      • MIKE GEARY
        Ray: Be aware that the balancer installation tool requires that your crankshaft has a tapped hole in the snout. The original 250-300 horse motors did NOT come with this feature. Hopefully your crank was gone through at some point and had the nose drilled/tapped. If you end up hammering it on, I believe the service manual shows the safest procedure. When fully seated, the timing tab will almost overlap the balancer.
        MAG
