I need some guideance from one of you engine experts: I have installed a newly rebuilt FI unit on my 62. The car is an original FI car, that had been missing the unit for quite a while. THe engine is a replacement 327, that is built somewhere close to the original 360 HP specs. Has about 10.5 compression, and a fairly stout cam, 2.02 heads, etc. I didn't build the engine, so I really don't know what the cam spec is. The previous owner described it as "radical but streetable". Whatever that means. This unknown cam may be a lot of my problem, but I want to explore all avenues before I change it.
The only way I can make the engine idle is with a lot of ititial advance. This was true with the carb that originally came with the car as well. It had an aftermarket tach drive distrubuter on it when I bought it. The ST12 calls for about 6 deg advance at 850 RPM. The only way I can get the engine to idle at all is with about 16 deg of advance. I really don't know what this number is, since it's off the timing scale! As a matter of fact, more is better,(faster, more stable) but I'm reluctant to give it any more advance. I had the same situation with the carb, but not as pronounced. Also, I'm getting a distinct engine vibration kicking in at about 2000 RPM. I had this with the carb also, but not until I fooled with the timing. I suspect it is timing related. (detonation???) The vibration is definately engine related and not chassis. I have considered the possibility that the timing marks on the balancer or on the engine are not correct. I didn't build the engine, so......? It was supposedly professionally built, but????. I'd really don't want to tear the engine down the find out, if I can avoid it. How much initial advance can I safely run? How about total? The ST 12 has some very low numbers for total as well. If I advance the timing much more than I have it now, I start getting some pinging if I lug the engine at all. I haven't tried any WOT operation yet. I want to get this timing issue settled before I get too froggy. Any advice would be greatly appreciated.
