I have a couple of alternator questions regarding my 1963 SWC driver. I had my alternator tested today when I replaced the battery. It passed in that it put out, I believe, 14.6 amps but the test indicated a bad diode pattern. The store did not appear to know what that means and suggested not replacing the alternator since the output so high. Should the alternator be replaced? If it matters, the existing alternator code is 1100834 37A.
Also, while I have you. I noticed that the specs call for a 37 amp unit for the car (324/340 w/o air). Mid-America shows a Delco unit with 55 amps for a 1963/64 Vette. Is there any downside for using a 55 amp alternator? What about something bigger?
Thanks in advance your response.
