Gas Tank Anti-Squeek Pad - NCRS Discussion Boards
  • Kieran A.
    • April 30, 1987
    • 87
    I recently removed the fuel tank from my 1967 coupe to get a good picture of the remaining tank sticker. In doing so one of the tank anti-squeek pads was pulled off the frame due to a large amount of dealer applied undercoating. I ordered a replacement piece from a large supplier,but it was basically a type of roofing paper and not the same as the original padding. Any ideas as where to locate a similar material; I hate to remove the good pad from under the tank support bracket.Thanks,Kieran #11373
  • Mike Geary
    Re: Gas Tank Anti-Squeek Pad
    Kieran:
    Your right, the parts suppliers are trying to pass off 30# roofing paper, and it's not even cut to the correct dimensions.
    I went to a local roofing supply house and found a piece of 90# asphalt-saturated roofing felt. That came pretty darn close to the original.
    By the way, on my '65 the strips were glue to the tank in contradiction to the AIM.
    Mike
    • Stephen L.
      • May 31, 1984
      • 3148
      I recently removed my tank from my 67 and it to had the anti rattle material glued to the tank with a brown adhesive which apparently had been applied to the tank (it was slopped on the tank) and then the felt strip laid on it prior to installation on the frame.
        Steve-----
        The adhesive is brown NOW, but I think that it was originally much more yellowish. The adhesive used was similar to 3M Super Weatherstrip Cement.
        • Kieran A.
          • April 30, 1987
          • 87
          Thanks for all of your help. I will visit my local building supply ASAP. As mentioned, my pads were also glued to the tank with what appears to be a yellow-brown contact adhesive. Thanks again, Kieran #11373
