Starter Solenoid - NCRS Discussion Boards
Starter Solenoid
  • Roger S.
    • May 31, 2003
    • 262
    Starter Solenoid
    What is the correct part number for the starter solenoid for a 1973 350 with an automatic transmission. The starter P/N is 1108430.
    Roger
    Re: Starter Solenoid
    Roger-----
    I believe that the original solenoid installed was GM #1114356. The current replacement is GM #1114458. In basic external configuration, these units are similar. The GM #1114356 was painted black out of the box and had a black plastic cap on the terminal end; the GM #1114458 is unpainted out of the box (zinc plated housing) and has a brown plastic cap on the terminal end.
