Can someone identify and provide the application of a flywheel with the casting number "14091559N". It bolts up to a late model Chevy crankshaft with a one piece rear main seal. This FW has the ring gear teeth for the starter on the transmission side rather than the engine side. TIA, John.
Flywheel
Re: Flywheel
John-----
Well, about all that I can tell you is that this flywheel has no Corvette application. All Corvette (and Camaro) one piece rear seal engines used flywheels of 12-3/4" and 153 tooth ring gear.
If it were not for the strange configuration of the ring gear on the rear of the flywheel, I'd say that this was a GM PART #10105832 flywheel. This is the 14" flywheel for one piece seal applications. However, this flywheel has the conventional ring gear orientation.In Appreciation of John Hinckley- Top
