The spring that goes between the door and door panel on my 60 is tapered. It's not clear from the AIM, etc. as to whether the large end goes against the door or against the door panel. It appears that if the small end goes against the door panel it will slightly protrude through the window crank hole.
Can anyone advise?
thanks, Rick
Can anyone advise?
thanks, Rick
