How do you remove the cylinder and key from the case on a mid year glovebox? For example, I know about the paper clip releasing the ignition cylinder from the switch. Is there a similar release on the glove box lock? I am trying to retain the 1963 case with round bezel and have a keyed replacement from paragon with a bezel that looks like a 1964...other than that they look identical...but how in the world do I get the cylinder out? I see two slots on the top of the cylinder...is that the trick?...does something stick in there to release it? Thanks for any help you can give me.
Cliff McComb
1963 Coupe
Cliff McComb
1963 Coupe
