I live in Dallas, TX area and have a numbers matching '65 coupe with 350hp 327, 4 speed, stock 3.70 rear end and factory air. Just completed a total frame on restoration and everything under the hood is new. Engine was bored .040 over and we put in flat top pistons to cut compression and runs great on 93 octane gas. Installed a Griffin aluminum radiator (a tad bigger than the original Harrison I think), standard 180 degree thermostat and 6 blade clutch fan (car originally had 7 blade fan but long since gone). Car ran beautifully at about 185 degrees with ambient temp 80 degrees or less, no matter what speed.
Finally got air conditioning system hooked up in June. Immediately noticed that engine temp was creeping toward 210-215 with air on, especially in traffic with ambient temp in upper 80's to high 90's. Decided to install twin 8" electric fans (800 cfm each) in front of condenser. They kick on at 180 degrees or when air is on. This helped my slow speed temp regulation immensely. However, took a 40 mile trip and noticed that the faster I went, the higher my engine temp. At 97 degrees outside and 70 mph, temp was running 230-235 with air on. Slow down and temp went down. Come to a stop light and temp dropped to 215. Start when light turned green and temp shot up about 10 degrees.
Made two alterations. Replaced fan clutch (it wasn't locking up properly) and put in a 195 thermostat. With ambient temp about 90 or 95 car runs about 210-220 with air on at 70 mph. Drops to 205-210 with air off. Still cools down quickly to about 200 with air on and speed below 50 mph or sitting at red light.
The increase in temp when I speed up baffles me. Shouldn't have anything to do with fans. You shouldn't even need a fan at 70 mph. I can't figure out why this car won't run at about 185 at any speed, with or without air on, using a 180 thermostat.
Has anyone else encountered this problem? Oh, yes, I have original shroud and fan sits half in, half out at back of shroud. I also don't believe stepping down in thermostat temp will help. It would seem water would flow too fast, not staying in radiator long enough to cool down.
I used to own a '66 big block roadster with factory air back in the late 60's and I don't EVER remember having any engine temp problems. And it was just as hot here in Dallas back then.
Any and all suggestions and comments are welcomed. Thanks.
