1. 1967 L79 carb List 3814 makes a high pitched whistling sound only at normal operating temp, but especially when backing out of the throttle. Vacuum leak ? If I need a rebuild, any suggestions for shops? Are the kits hard to find ?
2. Anyone have a picture of the L79 fan shroud ? I think I have the proper one but it is hard to tell with the assembly manual.
3. Last one for now- I have a non original AIR System. It has a different routing and a different diverter valve- attached to the pump itself. Any suggestions for a source for the proper system ?
Thanks in advance for your help.
