If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
This past Sunday I observed what I think is gas percolation in my 1960 270HP Corvette. After driving about 30min.,I stopped my car and turned off the engine because it seemed to be idling rough. I removed the air cleaner and I could see gas coming out of one of the nozzles on the rear carb. I remember reading post about one year ago about percolation and checked the archives. There were several suggestions,i.e. fuel line insulation,octane booster,checking carb. vent. Has anyone fixed this problem and by what means? Thanks in advance for any
advice.
This is frequently one of the joys of the newer re-formulated and/or oxygenated gasolines. Several things help here - one is double gaskets under the WCFB's to help insulate them from manifold heat, another is to change the float settings from the original 1/8" (primary) and 1/4" (secondary) to 1/4" and 5/16" to allow space in the float bowls for expansion.
Last week I blocked mine on one side and put the restrictor insert on the choke coil side (just in case I ever went to a non-electric choke carb setup). I also made some other changes to the initial timing in the distributor and some fuel changes to get rid of the excessive octane/lead additives. I know this is not the "scientific method" but I do not have unlimited time lately to do these things indepenantly of each other then test and evaluate each change one at a time (is that a "Yogi-isim"?). The results were sucessful in curing a hot soak carb issue but the minor downside is what was warned that I now have a minute or 2 longer warmup requirement for the carb. Nothing I can't handle and worth the sacrifice without question.
with a aluminum intake should be no problem but cast iron manifolds take forever to warm up but they do not transfer the heat to the carb like the aluminum manifolds so a heat insulator spacer under the carb may work on a cast iron manifold instead of blocking the crossover.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
