Transmission pops out of 2nd gear - NCRS Discussion Boards
  • tom vogel
    My transmission has popepd out of 2nd gear on the downshift (unless u hold it place) for some time now. Is this a 2nd gear problem or more likely a 1st-2nd gear hub issue...or something else maybe?
  • Tim anderson
    Re: Transmission pops out of 2nd gear
    Syncro rings, keys and slider. Some say to replace the hub it all rides on at the same time. But unless it was real ugly...... I wouldn't. However I have seen the whole set sell as an assm. Hub,rings, keys, and springs. Where to buy is a total loss on me. It has been too long since I have needed them.
    • Bill Clupper
      If we are talking T-10 here, usually it is a combination of worn synchro teeth on the gear iteslf and the mating slider. There are special slider available to compensate for this if the gear teeth are not too bad. Available from Ed Hartnett 4 speeds, 610-623 9361
