Here's what happened several weeks ago. Could I get some opinions on what might have been going on?
My '67 L-79 was caught up in some traffic. It was 85 degs.+, and no air to speak of. I decided to let it idle after sitting several minutes of not knowing what was up ahead. Little by little, the temp gauge rose to 210+. By then, I knew either I needed to get going again, or shut it down. What should I do? So, I left it run a little more, and eventually turned it off, 'cause the traffic wasn't budging.
Finally, traffic opened up in about five minutes or so, and I cranked it. Healthy crank, turned over well, but nary a hint of firing up. More crank, still no fire. Finally, I pulled it over (on a slight down-grade) and popped the hood. Let it cool down for about an hour, then cranked it. Fired instantly, temp was down to 180 or so.
Anyhow, what was going on? Vapor lock? If so, can it be prevented. By the way, it's never done this before.
Thanks for input.
Tom
Thanks for input.
Tom
