Ignition Timing C2 Big Block - NCRS Discussion Boards
  • John Lokay
    What should the total timing limit be for a C2 Big Block (1966; 425hp; factory clone type cam) and at what RPM range should it be all in by? Thanks
  • Bill Clupper
    Re: Ignition Timing C2 Big Block
    Factory Distributor, 15 dist degrees (30 crank) @4600 engine RPM. advance starts @ 1000 RPM (engine) Vacuum adv 15 degrees @ 12 inches. I believe initial timing is 10 degrees.
