I've owned my 67 L79 for 7 years and since I've owned it I've had this issue with the transmission and would like some opinions.
The issue is when I want to shift the transmission fast it clashes the gears. This only happens on upshifts. The clutch and linkage seem to be fine and if I use a slight hesitation between upshifts it isn't a problem. It hasn't gotten any worse over the past 15,000 miles but I know this shouldn't be and would like to know what the problem is. Thanks in advance for sharing your thoughts.
