'64 Starter Motor Replacement - Need Advice - NCRS Discussion Boards
  • Ed McGettigan
    I'll be replacing the starter motor in my '64 with an L75 and 4-speed transmission. It seems pretty straight forward. Any secrets/tips that anyone can share to make the job as painless as possible would be appreciated.
    Ed #31248
  • Mark J.
    • March 1, 1996
    • 254
    Disconnect battery and inspect terminal wires
    Determine which wire goes to which terminal on the solenoid for easy reassembly. Also, the two nuts on the solenoid are typically different sizes. If you are replacing the starter with an exact replacement, the rest should be easy.
    Mark
