My 1966 coupe has what appears to be "factory" overspry on the sides of the rear storage compartment. This is the same compartment that olds the jack. On both sides of the compartment there is overspray. I think it is factory because in some places the overspray has been covered by undercoat. Also, this area would not have gotten paint if the body was not off the frame because the trailing arm is directly along side thus blocking the area. The trailing arm hs no paint on it. So I assume that the overspray orginated when the body was off the frame. Since this car has never had a frme off restoration or any restoration for that matter I assume this factory overspray. Right?
1966 factory overspray ?
