Currently installing the trailing arms. With new bushings, the old # of shims do not fit. I know when completed the car will have to have to be aligned, front and back. Question is, how many shims are needed to keep the trailing arms stable, until the car can be taken to get aligned? Also, the replacement shims I obtained have two holes? After installing the bolt in, where does the other end of the shim go to?
French locks? Do they go on the outside of the inner flange? The outer clips bend over the bolts? But which way does the rest of the lock bend, towards the wheel or out towards the differential?
