!990 ZR-1 / LT-5 - NCRS Discussion Boards
!990 ZR-1 / LT-5
  • George C.
    • December 1, 1988
    • 583
    !990 ZR-1 / LT-5
    Can someone confirm that the 1990 ZR-1 engine block for sure has a pre drilled hole in back of block for drainage for the starter. Save the wave. >George
  • Kris Schmalenberg
    Re: !990 ZR-1 / LT-5
    As far as I know all LT5 engines have this drain hole. My 94 does, but it is larger then the earlier years. There is also a tube that runs from this hole to below the oil pan rail. Hope this helps.
