Broken bolt - NCRS Discussion Boards
Broken bolt
  • Steve D.
    • February 1, 2002
    • 990
    Broken bolt
    Is there a secret to drilling into broken bolts ? I'm using a carbide tipped bit, and still can't make much headway. I broke the left rear body mount bolt, and I'm trying to drill a pilot hole for the eazy-out.
    Steve
  • John D.
    • August 31, 2001
    • 280
    Re: Broken bolt
    Steve:
    I have had some luck using a cobalt steel drill and a slow drill speed.
    John
    • John M.
      • January 1, 1999
      • 1553
      Re: Broken bolt
      Some carbide tipped drills are meant only for hammer drills and will not drill in metal worth a hoot. A standard high speed steel drill bit should be good for at least 10 holes before going dull if you keep the speed down. If you are not making a good headway, you probably have a masony drill for a hammer drill.
      Regards, John McGraw
