Looking for information 1959 Parking alarm - NCRS Discussion Boards
  • james Levandowski
    Does anyone have information on the Parking brake alarm I have the light and the lead from the instrument cluster but do not have the switch or flasher or where they attach to. All the manuals I have do not give a clear picture or where this hooks up. Thanks
  • Chuck G.
    • May 31, 1982
    • 2029
    Re: Looking for information 1959 Parking alarm
    Since the parking brake alarm was an option in 59, code 108, check in the back of your 59 AIM, in the "options" section. You'll likely find an installation and wiring diagram there. Chuck
    • james Levandowski
      Thanks Chuck I can find the wiring diagram but no picture where the switch sits on the parking brake?
        James -
        Should show in the options section (FOA 107-Parking Brake Alarm) at the back of your Assembly Instruction Manual. If it's like a '57 (don't have a '59 A.I.M.), it mounts to the park brake tube with an integral binocular-type screw clamp, and is actuated by a short pin in a hole in the top surface of the rod the handle is attached to.
