Re: SHP Big block idle problems
Duke and I have been corresponding recently about vacuum and idle issues on my own L72 (single carb, 3247 Holley). I thought (assumed) the 3247 used full vacuum for the advance, but mine almost behaves like it is ported. At idle the vacuum is 2" - at the distributor advance line. As soon as you move the throttle, the vacuum starts to come up. I still don't have the definitive answer yet whether this carb is intended to be ported or full vacuum. I am going to measure the vaccum at another source - the choke pull-off line.
Another item which can add to poor idle is the PCV valve - a "bad" one can cause rough idle, which contibutes to poor vaccum, which contributes to more PCV valve (and advance can) dithering - the same feedback loop Duke mentioned previously. On my other L72 car, when I replaced the PCV valve, the car idled beautifully, even with the stock vacuum can, so I am going to replace the PCV on this car to see the contribution to idle quality. The service manual says to remove the PCV valve from the line and to plug the line and note the RPM drop - if less than a 50 RPM drop, the valve is supposed to be bad.
