57 4 speed - NCRS Discussion Boards
57 4 speed
  • Verle R.
    • March 1, 1989
    • 1163
    57 4 speed
    Can anyone verify the identity of this transmission?
    Aluminum Tail shaft :
    6 13 57 SPAC T 10-7 WG Division
    Cast Iron case:
    T 10-1 WG Division 02
    Small tag : 4 - 2
    Thank you,
    Verle
    Re: 57 4 speed
    Verle----
    The maincase and extension housing casting numbers are consistent with a 1957 T-10. The maincase casting was used for several subsequent years, also. However, the -7 extension housing casting was unique to 1957. Subsequent years used -7A.
    • Loren L.
      • April 30, 1976
      • 4104
      What size are the tailshaft
      mounting holes - 3/8" or 7/16"?
      • Verle R.
        • March 1, 1989
        • 1163
        Re: What size are the tailshaft
        mounting holes?
        Which holes are you referring to?
        tailshaft to main case
        shifter
        transmission mount
        Thank you,
        Verle
