What type of paint should I use on my drums and backing plates for my 1961? Thanks for the help, Joe
Painting brake parts
Re: Painting brake parts
Duke and Joe-----
I believe that the backing plates were originally painted a high gloss black. With respect to degree of glossiness, I'm less sure about the brake drums, but I think that they were medium to semi-gloss black. Heat should not affect the backing plates too much, so a standard automotive paint ought to suffice. However, high heat paint in gloss, semi-gloss, and flat black are available from VHT paints and other suppliers. I'd use the 1400 degree variety on the drums.In Appreciation of John Hinckley- Top
The drums, backing plates and for that matter the entire rear axle assembly was delivered from Detroit Gear & Axle in medium gloss black paint. John Deere medium gloss enamel is ideal.
The judging guides and many judges believe that the drums were unpainted. If you are looking for points call your Team Leader and ask what he wants to see regardless of the way the Corvettes were built.
Dale Pearman- Top
