I am in the process of replacing my convertible top. I replaced the front header tack strip without a great deal of difficulty. I cleaned the dovetail grove really well before starting. I simply pushed the strip in until it was about half way before running into problems. I then put some longer screws in the t-nuts, and tapped them sideways to move the tack strip along. Didn't really take too much effort to get it installed.
Now my question. I am trying to put the front weatherstrip in place to adjust the top frame before installing the top. I am having a real hard time getting the metal retainer strips screwed into the t-nuts that are in the tack strip. The weatherstrip seems to be too thick for the screw holes to line up. I can't push the strip back far enough to get the screws started. Has anyone had this problem? Any quick solutions?
The second problem is that the t-nuts want to spin if I put any torque on them. Should they be glued in place or something?
John
John
