E brake cables and 'Horseshoe' clips - NCRS Discussion Boards
  • Pete VanSeggern #30920
    The rear emergency brake cables I got for my '63 have small thin black washers where the cables pass through the backing plates and frame. I don't really understand where the 'horseshoe' clips go or even if they are required for these cables. Any advice or experience here?? Thanks in advance for any responses.
  • Peter J.
    • September 30, 1994
    • 586
    Re: E brake cables and 'Horseshoe' clips
    Pete, Where the cable passes through the bracket on either side of the car - this where you use the horseshoe clip. Between the lip on the cable and the bracket.
