'66 pedal bushing replacement - NCRS Discussion Boards
  • Chip Levick
    I am attempting to replace the four plastic bushings in my clutch/brake pedal assembly ('66 roadster). I took the clip off that is on the end of the shaft, to the right of the brake - but that only allowed the shaft to move a couple of inches to the left. As a result, I can only get to the one bushing on the far right. How do I get to the other three?
  • Geoff C.
    • May 31, 1979
    • 1613
    Remove the brake/clutch pedal assembly *NM*
