C3-LT1 oil pan removal - NCRS Discussion Boards
  • Peter M.
    • April 1, 2003
    • 137
    To all,
    My oil Pan has a leak and I have purchased the proper gaskets. Is there anything special that must be done to drop the oil pan or will it just unbolt and clear everything if I put it on jackstands? Is this an easy job?
  • Craig S.
    • June 30, 1997
    • 2471
    Re: C3-LT1 oil pan removal
    Peter - it's easier than many other cars, you do have to drop the steering linkage on the idler arm...just use a good puller vs pickle fork to avoid damage to the boot. If you don't have one, Auto Zone lets you borrow tools...good luck!...Craig
      Peter -
      If you set the timing index mark on the balancer at 5 o'clock, you'll have more clearance to remove/install the pan at the front (in that position, the front crank counterweight will be up out of the way).
        • 11608
        Based on my experience with my 71 last winter, turning the crankshaft like this is mandatory if you want to get the pan out.
        I went with the new 1-piece gasket from Fel-Pro, and I like it much more than 4 piece original-style ones. If you use a 1-piece unit, make sure you get the pan mounting flange straight. I had it practically perfectly flat before I reinstalled, and no leaks since then.
        While you're in the area, consider replacing the rear main seal. You'd hate to have to do that again next winter.
        Patrick
