What is the silk screen on the bottom a '67 air cleaner top supposed to say?
'67 Air Cleaner Silk Screen
Re: 67 Corvette with 427
"Service Insructions"
REMOVE FILTER FROM THE SCREEN-WASH IN KEROSENE-SQWEEZE
-DO NOT WRING-DRY COMPLETELY WITH LOW PRESSURE AIR.
DIP IN 10W30 OIL-CAREFULLY SQUEEZE OUT ALL EXCESS OIL.
REPLACE FILTER SO THAT TOP AND BOTTOM OF
SCREEN IS COMPLETELY COVERED ALL AROUND.
AND A RECTANGLE THAT HAS A "AC" CIRCLE IN THE MIDDLE, THE LEFT SIDE SAYS:
INSPECT FILTER ELEMENT
EVERY 12000 MILES.
MORE OFTEN UNDER
SERVERE DUST CONDITIONS.
"UNDER THIS PART SMALL PRINT THAT SAYS" "AC SPARK PLUG".
ON THE RIGHT SIDE:
FOR REPLACEMENT
USE A273C
FILTER ELEMENT.
"UNDER THIS SMALL PRINT THAT SAYS" "FLINT MICH."- Top
Re: '67 Air Cleaner Silk Screen
My 67 327=350hp top cover in raisd numbers bottom side is
Service Instructions usa
--------------------- AC
service air cleaner breather and A212CW
CZ crankcase vent valve in accoro filter
6487699 with owners protection book
AC filter element are pre-
oiled for greater capascity
do not wash or blow with air
I tryed to lay it out but see that when I post it , that wont work!- Top
