60 Radiator - NCRS Discussion Boards
60 Radiator
  • Terry K
    60 Radiator
    I am installing a new Dewitt top tank radiator in my 60. On the bottom of the radiator is a welded on piece of aluminum "L" channel - complete with three gussets - this is a real nice reproduction!! When I slide the radiator in place, the bottom edge of the "L" channel comes down direectly on top of the front edge of the recieving "U" bracket. Don't laugh! Is this "L" channel supposed to be bent inward a little bit and go inside the "U"? or should it be bent outward a little bit and go outside the "U" channel?
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 60 Radiator
    Which Radiator support do you have? Does it drain on the driver's or passenger side?
    • Terry K.
      • July 31, 1975
      • 82
